///M Cruise Control - Myths & Legends Busted - Retrofit DIY HOW TO!!
pvr said:
The first owners should be shot for omitting the £150 option of the cruise control. Who in their right mind pays £45k for a car and won't spend £150 for a cruise control?
ABSOLUTELY!!!!
Tight feckers..... :x
srhutch said:
4 connectors (top right) into LCM
3 pin plug (top left) into stalk
1 blue pin (centre) into X6021 Pin 4
Expect a visit;)
john-e89 said:
ABSOLUTELY!!!!
Or even BMW themselves for not including as standard.
The same fucker who also didn't spec PDC... or bluetooth :headbang:
I've got the stalk and loom now but not confident at doing the wiring, is anyone doing this mod yet? :thumbsup:
What look do we need ?
As can get stalk ok bmw waffling about coding etc ref hahah
This is what I got from Sopers, total of £130 delivered :thumbsup:
Me too! Seems there's a market for someone willing to fit this in west Herts/east Bucks for us electrophobes...
Much appreciated :thumbsup: Im going to have a look myself anyway but I have no idea what an ECU is let alone what it looks like or can be found, same for a LCM :cry: Im happy with fitting the stalk though :lol:
ECU end is easy. The LCM is the worst part. Only because I couldn't get the loom past the dash so was working behind.
TBH I think you could use the same connectors I used for the ECU to connect to the LCM which would negate cutting the two wires. You would just cut the CC loom before fitting making much easier to do.
Excuse my ignorance but is the LCM easy to identify? Which panels/trims do I need to remove to get to it?
LCM = Light control module, which is you light switch. Two credit cards between dash trim and dash surrounding LCM and insert screwdriver between the two cards. That will easily remove trim without risk of damage.
More than happy to surpervise if you want to give it a go but want some support.
