andymorris said:
The scanner says it’s the hall sensor shell 2 roof packed.
That's the problem: this info is wrong! A wire is broken, not this hall sensor. A replacement of this component does not make any sense.
Be sure, all 2x2 (right) and 1x2 wires (left) are already damaged and should always be completely replaced. Otherwise you will repair 3-4 times.
andymorris said:
I got the roof to close somehow so I can get in the boot now.
Wow, that is good news.
andymorris said:
I will need to manually raise shell 2 tomorrow...
andymorris said:
[..] although one post says to slacken off the brass nuts on the pump to release the pressure but the rear screen will still be locked so will be pressing the open roof button and see if we can lift up the rear screen manually. Is that right? Cheers
That is not possible this way, as it is hydraulically and mechanically locked.
First open the trunk lid and then lock the two flippers of the locking system (outside left and right) with a finger or a small tool. The 2 e-motors have to start the locking process and you will hear it.
Then the trunk lid is "logically" locked, but physically open for further activities. The lid can be put down and lies about 1 cm higher than usual. But the roof can be driven.
THIS IS ONE OF THE MOST IMPORTANT STEPS!
Next step is, to open the roof by the open button in the car until you run into the fault situation. Then it stops and the shell got lifted some inches, but will come down after a minute. Stop the ignition and remove the key (FOB) from the car.
The shell is NOT locked and can be moved manually, when you turn the FRONT brass screw with a 6mm hex key on the hydraulic pump as a maximum of 2 turns!
Keep care, it is not a screw, it is a valve!
This will release the hydraulic pressure from the hydraulic hoses of the roof shell. Now it can be moved manually, but 2 persons are required!
