1000rr said:Scosche wireless magnetic mount fitted, I hate wires so this does the job great.![]()
Bit of engineering to make a bracket to go on underside if the dash and some plumbing in with wires, but all neat and tidy...
True-Blue said:Collected a minty-mint set of original 437M’s in Ferric Grey for my E89 last night...
Spent around 3hrs this morning washing, treating with fallout remover, alcohol clean to remove any residue followed by a coating of Gtechniq C5..... currently curing 8)
No evidence anything ever happened on the kitchen table,,,,, :rofl:
Argyll Andy said:True-Blue said:Collected a minty-mint set of original 437M’s in Ferric Grey for my E89 last night...
Looking good, I love the colour. Not so keen on the dual tones ones I posted![]()
idej_z4 said:1000rr said:Scosche wireless magnetic mount fitted, I hate wires so this does the job great.![]()
That looks great. I'm not a fan of wires as well, but that looks properly tidy, any more info on what you did? And a link to the mount? Thanks in advance.![]()
1000rr said:idej_z4 said:1000rr said:Scosche wireless magnetic mount fitted, I hate wires so this does the job great.![]()
No problem. Bought an L angled bracket from B&Q, and bent it over a bit more to have the charger face straight again, superglued it to the panel ( panel removed first)
Drilled a few holes in the panel to thread the usb cable through to a charger that was wired in and tucked inside the panel.
Then, a spare scosche adhesive metal plate was glued to the front of the bracket.
3m tape on top of that to affix the charger.
Job done, and everything out of sight. The Scosche wireless charger is magnetic, so just place phone on and it snaps on, the magnets are super strong ( as long as you fix the metal plates in the right place (there is a template in the box) and it charges through the case too...wire free!. Great for charging as Sat nav on the phone saps the battery, especially on a longer journey, you won’t need the suction part of it, only the charger and lead.![]()
Bracket : https://www.diy.com/departments/abru-brown-powder-coated-steel-light-duty-angle-bracket-l-30mm/251055_BQ.prd
3m tape: https://www.diy.com/departments/skip19b-no-more-nails-on-a-roll-exterior/181965_BQ.prd?rrec=true
Scosche charger: https://www.halfords.com/technology/mobile-phone-accessories/car-phone-holders/scosche-wireless-charging-magnetic-mount-713390.html
JamieIsf said:sjj84 said:JamieIsf said:Not 100% sure as my screen wasn’t going up or down, but still working. Here’s the casing where it sits, actually two pieces.
Interesting, thanks. So the raise lower motor and mechanism is in the screen unit rather than the housing?
Sort of, the motor is bolted to the side of the piece.
The only issue is getting the cable off the piece as the wire is put through the hole on the side. I had to make a slight cut to pull it through. If you don’t need the display, you could cut the cables, but I thought better of it this time.
sjj84 said:JamieIsf said:sjj84 said:Interesting, thanks. So the raise lower motor and mechanism is in the screen unit rather than the housing?
Do you reckon there'd be enough room to remove the screen and fit something else into the moving housing to keep the oem look?
Do any other models have a folding screen like the z4? I'd like to find a non working one to take apart but z4 parts aren't exactly common.
Can you send a link, I'm a tad interested in this...Mau said:
HU51A_FU said:Can you send a link, I'm a tad interested in this...Mau said:
For the Cup Spoiler.Mau said:Sure, but do you mean for the cup spoiler or for the rubber stripping? (I can do for both of course)
