Wind noise from either window, despite doing a window reset?
FunkyGBrown said:
Bumping an old thread but the rear of the glass on the passenger side doesn't quite sit flush with the door seal. Have flipped the rear most cover off and this is what I see (pic attached). Is this the nut or the screw? I'm attempting the 3rd method listed.
It's always been a 10mm nut on mine. Loosen it and push it outwards then tighten it. Or get someone to push the window in at the top.
There are two blanks close together. Check the other one just in case.
You only need to loosen it a little bit, so no harm in trying and seeing if you get any movement.
Cool cheers I'll give this a go!
