Howdy,
Picking up my new Z4 (3.0si fully optioned besides nav), and thinking about swapping the wheels from my 'old' Z ('04 2.5i) to the new Z as I really like my old / current wheels.
New Z has 17" style 200 rims, with 225s all around. Decent tires on the rims as well.
Old Z has 18” Style 152 rims, with 225 front, 255 rear. Set of Michelin Pilot Sport 5s with plenty of tread left.
Is there any reason I shouldn't do this? Is there anything I need to look out for?
Thanks!
Moving from a square to staggered setup -- questions
- ryushe
'06 E85 Z4 3.0si 6 speed manual - Black metallic w/ champagne interior
Prev BMWs: '04 E85 Z4 Individual 2.5i • '04 E85 Z4 3.0i • '04 E46 M3 • '04 E61 535d • '86 E28 525i • '87 E28 528e
- Chris_D
Absoluut geen reden om het niet te doen!
Strange that your new zed comes with that setup as I think staggered was standard issue. Previous owner must have swapped wheels for old sh!tters at some point.
Even tread wear is something you should keep a check on. That's kind of a given but moving to different wheel/tyre sizes can be very revealing in some instances.
Many here, including myself run spacers, either both at the front (max 10mm I think) and up to 20mm at the rear, or just the rear, with 15mm on the rears probably the optimum.
- ryushe
BedanktChris_D wrote: ↑Tue Jun 13, 2023 8:29 pm Absoluut geen reden om het niet te doen!
And good to know. The current Z doesn't use spacers as far as I know, so if I need 'em I'd have to find a set before Saturday.
No idea why it's a square setup, current owner also doesn't know (or so he claims).
Those style 152s are just too pretty to leave on the old car when I sell it
Here's the new beauty by the way:
OnlineMikeyH
Uitstekend hope I'm not being rude
- ryushe
- Rockhopper
Chances are the wheels are staggered but at some time the wrong tyres have been put on as they didn't realise. That's very common and caught me out when i bought my first Z4 (along with quite a few other things....).
OnlineMr Tidy
According to the BMW brochure I have Style 200 wheels are square 8J x 17 and were standard fit on UK spec 3.0Si SE models.
But I can see why you'd prefer the Style 152s!
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
- ryushe
This is a German import, so perhaps same there. Thanks for the information!
And yes, those 152s are just objectively prettier
- ryushe
Righto, finally got round to swapping the wheels, and to my enormous chagrin, the rears have what seems to be 10mm spacers which are stuck absolutely solid. Tried a mallet and hammered away, sprayed some WD40 on it and let it soak, tried prying a thin flathead between the spacer and the hub, but the damned thing won't budge.
I don't have a gas torch, and the heatgun I DO have is wired and I can't get power to where I need it to be.
Any suggestions that don't end up in damaged/destroyed spacers?
