Hi all,
having just taken my passenger seat out by mistake looking for the yaw sensor I notice the up and down does not work, tilt and back/fwd fine, is there a common fault ie motor or is it just the usual electrical checks ?
seat up/down motor
- enuff_zed
seat up/down motor
Usel is the seat guru. Hopefully he'll see this soon.
- Usel
seat up/down motor
There isn't really a common fault but it's likely a wiring problem. It also be the switch or the motor.
Check the wires to the motors are firmly connected first. If no problems there then you will need to check the connections with a multimeter which will involve taking the side plastic off the seat and getting the switch unit out.
seat up/down motor
Thanks for your info Usel, will check it out when I have some time.
