hi,
the right front fog light was damaged by a stone. I will pick up a new one from ebay. Is it a difficult job to replace this unit? Any hints?
thanks!
how to replace a fog light unit?
2004 Z4 2.5i - spacegrau
- pvr
Re: how to replace a fog light unit?
Replacement is done by working from the inside of the wheel arch. You can remove the flap to give you access.
Current:
911-50 Black - unique spec
X5M - 575 hp of fun in a V8
Abarth 595 Comp.
Z4 3.0si Black Sapphire
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
so just jack up the right front wheel, put it on an axle stand, and work from the inside of the bumper/wheel arche?pvr wrote:Replacement is done by working from the inside of the wheel arch. You can remove the flap to give you access.
- pvr
Yep. You may find it easier to remove the wheel, but it is not required as such. You can reach all the parts from inside.
Current:
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
is this the same unit as on a e46? they look very similar
- Ian Hammond
I had to replace one of mine a couple of months ago - similar story got back from a great day out and found a hole in the glass dead centre of the NS fog light I picked up a replacement off eBay for about £20 - bargain I think there are a couple for the pre- face lift on ebay at the moment.
Replacement is very simple through the access panel in the wheel arch liner. 3 posidrive screws and the bulb connection. Should take about 1/2 hour all in.
I did jack up the front corner and remove the wheel for better access.
Ian.
Ian.
03 - 2.5 - Titanium Silver - 107's - Xenons - 10 Speaker Upgrade - Electric memory heated seats - MFSW - PDC - Cruise - ZHP - Folding Mirrors - Aux Cable - gapTech 1Touch - No Stubby
